Cool Efficiency Redefined
Cooler Master’s masterclass HYPER 212 series makes a triumphant return with the HYPER 212 PRO, a new take on a classic design featuring our in-house design heat pipes.
Higher TDP
The newly designed CPU cooler introduces an all-new heat pipe, increasing the TDP to 230W. This means it can handle the cooling of higher power CPUs effectively
100% RAM Clearance
A novel asymmetrical heat pipe layout and design provides more RAM clearance than ever before.
Optimized Tower Cooler Design
The optimized design ensures better airflow and heat dissipation, which results in improved cooling efficiency and overall system performance.
Superconductive Composite Heat Pipes
By using various evaporator and condensor wick structures, our SCHPs greaty enhance performace for improved heat dissipation
All-new Top Cover Design
A sleek and modern top cover enhances the overall look of your build, giving it a stylish and professional appearance.
SickleFlow Edge 120 Fans
A SickleFlow Edge fan combines exceptional heat dissipation performance with a visually striking design.
Easy fan mount
Simplifies the installation process, allowing users to set up the cooler quickly and efficiently.
