HAF 700 embodies the spirit of HAF's performance oriented design, boasting attention to mechanical detail.
The Berserker
HAF 700 Full Tower PC Case
HAF 700 - Cooler Master EATX High Air Flow PC Case, Mesh Front Panel with 200mm SickleFlow ARGB Fans
Hardware & Connectivity
No Limits
The HAF 700 is capable of housing up to SSI-EEB motherboards (E-ATX), as well as any sized graphics cards in BOTH horizontal and vertical orientations.
Rich Connectivity
The front I/O is designed to maximize the front connectivity for most high end motherboards, featuring four USB Gen 3.1 Type A ports, a USB Gen 3.2 Type C, a 4 pin audio/mic headset jack as well as a dedicated mic jack.
MAMMOTH RADIATOR SUPPORT
HAF 700 comes with dual exclusive 200mm Sickleflow ARGB PWM "Performance Edition" fans tailored to strike a balance between performance potential and noise levels
HAF 700 sports a fully meshed front panel, specifically designed
to allow for maximum air intake. With the front panel structurally
reinforced to prevent resonation caused by fan vibrations, systems
can run smoothly at minimal noise levels.
INTEGRATED HUB
The unique removable top panel design allows you to effortlessly install, reach and maintain cooling components such as fans and radiators even in builds with complex custom cooling systems. This, coupled with the rotatable radiator/fan bracket included out of the box allows for an unparalleled building experience.
HAF 700's structure segregates non heat sensitive components so heat dissipation can be targeted towards heat sensitive components at an overall higher efficiency.
ARGB Gen2 Ready, Controller Included
ARGB Gen2 technology allows users to explore full range customization down to the lighting effecting of each individual LED, while remaining compatible with third party devices.
