Power Evolved
Cooler Master G Gold 650 V2 | An every day ATX 3.1 upgrade
G Gold V2, the upgraded version of the G Gold featuring ATX 3.1 support, high temperature resilience and 80 Plus Gold efficiency.
Power Evolved
Cooler Master presents the G Gold V2, the upgraded version of the G Gold featuring ATX 3.1 support, high temperature resilience, a quiet HDB fan, 80 Plus Gold efficiency, an embossed cable, and a 5-year warranty.
ATX 3.1 Support
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, this unit is ideal for use with the 40 series GPUs.
Embossed Cable
Quiet HDB Fan​
Exceptional Efficiency
The G Gold V2 is certified to achieve more than 90% efficiency at typical loads.​​
High Temperature Resilience
PSU Calculator
