Tiene tu espalda
ERGO L Ergonomic Gaming Chair
Cooler Master ERGO L está diseñado para la máxima comodidad que mejora la postura general de su cuerpo sentado.
Work & Play Never Stops
Say yes to a chair that can take on any number of hours in front of your screen, be it for productivity or gaming. Build for utmost comfort, our Cooler Master Ergo Chair bridges the gap between performance looks and seated well-being for the champions that give their all every day. Better cooling and improved ventilation for longer sessions is provided by the breathable MuscleFlex® high tension mesh that also creates a unique suspended seating comfort with less fatigue and pressure. Get ready for work & play’s next level!
Designed for Comfort and Cooling Performance
Cast Aluminium Strength
Ergo L sports a 3D-engineered Cast Aluminium frame that synchronizes armrest with seatback reclining in a unibody design. This lightweight material doesn’t just look pristine but offers hours on hours of consistent performance and durability.
Hard Frame, Soft Core
The Ergo mesh seat and backrest undergo rigorous testing with over 20.000 cycles of abrasion, load and tensile tests. It’s rigid yet soft, subtle but powerful, the perfect companion for those who desires to be at the top of their game.
Effortless Personalization
Versatile Adjustability
Featuring unique adjustments options such as seat depth and independent reclination, our Cooler Master Ergo L defines new depths of personal comfort!
Mesh Me Up!
Breathable MuscleFlex® high tension mesh is a ballistic-like material that strikes the perfect balance between strength and elasticity whilst providing uncompromised tenderness for all body shapes and weights! Tested at 100,000 cycles against impact and Technical Bulletin 117-2013 Smolder Resistance, the Cooler Master Ergo L can take a serious beating and still come out victorious. Like player, like chair.
