![](https://a.storyblok.com/f/281110/1730x1122/b3882c65d0/image-overlay.jpg/m/1700x0/smart)
Infinity Mirror Design
Support your GPU in style with our patented, industry-first infinity mirror design, encased in a transparent layer that creates a trippy visual effect like you've never seen.
Introducing Cooler Master's Atlas ARGB GPU Support Bracket featuring an infinity mirror design, edge-lit ARGB tempered glass, an aluminum stand
ARGB lighting rails have been added via CNC machining on the tempered glass, bolstered by enhanced lighting thanks to extra ARGB bulbs. The edge-lit, transparent design provides an aesthetic accent without blocking your card. Alternatively, turn off the lights for a near invisible aesthetic.
As GPUs like the 40 series become larger, PCIe slots may suffer
increased stress. The Atlas eliminates this by supporting the GPU's
weight at critical points throughout the length of the card.
Our strength testing shows that the Atlas can support the heaviest
of cards without even flinching.
A fully aluminum stand provides strengthened and stylish support, built from premium materials specially designed to hold up even the heaviest GPUs.
The Atlas' design allows for hassle-free adjustment via a sliding and locking mechanism that is compatible with a wide range of builds. A dual axis support mode allows for both vertical and horizontal configurations.
As GPUs like the 40 series become larger, PCIe slots may suffer increased stress. The Atlas eliminates this by supporting the GPU's weight at critical points throughout the length of the card. Our strength testing shows that the Atlas can support the heaviest of cards without even flinching.
With its 100% tool-less design, installation and adjustment is painless. A rock-solid base is further reinforced with magnets for extra stability.
