NR2 Pro
NR2 Pro
EXPERIENCE STUNNING VISUALS IN DEMANDING WORKLOADS
The NR2 Pro Compact High Performance PC is designed to deliver exceptional 4K performance for visually demanding applications. Explore immersive creative projects, high-resolution contents, and the latest AAA games with outstanding visual fidelity.
EXCEPTIONAL PERFORMANCE
FOR WORK AND PLAY
The Intel i9-14900K delivers remarkable power with 24 cores (8 Performance, 16 Efficiency) and 32 threads. Its Max Turbo Frequency is up to 6GHz, ensuring smooth multitasking across demanding applications, content creation, and everyday computing.
IMMERSIVE GRAPHICS
AND NEXT-GEN FEATURES
The NVIDIA GeForce RTX 4080 Super delivers cutting-edge visuals, redefining what's possible in both gaming and creative workflows. Immerse yourself in stunning ray-traced environments and boost performance with AI-powered DLSS. The dedicated NVENC encoder ensures smooth and high-quality streaming so you can share your best moments effortlessly.
MAXIMIZE SYSTEM POTENTIAL WITH HIGH-SPEED MEMORY
Equipped with 64GB of high-speed DDR5-5600MHz memory, effortlessly juggle multiple applications, demanding games, and creative projects without compromise. Experience smooth and responsive performance that enables you to focus on the task at hand.
HIGH-PERFORMANCE STORAGE SOLUTION
The 2TB NVMe Gen 4 SSD delivers blazing-fast performance for games, creative workflows, and everyday use. Minimize load times and enjoy the freedom to store your game library, videos, and other large files without compromise.
SMALL FORM FACTOR, PRECISION COOLING & BIG PERFORMANCE
The NR2 Pro Compact High Performance PC features a 280mm Cooler Master AIO liquid cooler and a highly-advanced 3rd-generation CPU pump, ensuring efficient heat dissipation. Maintain optimal system temperatures for reliable and high performance computing under demanding workloads.
Buy Now for the ultimate performance boost
Upgrade your gaming experience with a full PC from Cooler Master!
Full PC
NR2 Pro i7/4060ti
Z790I WIFI DDR5
Intel Core i7-14700F
280mm radiator, 2 x 140mm SickleFlow PWM,
Gen 3 Cooler Master Pump
GeForce RTX 4060 TI 8GB
Cooler Master NR200P Max
32GB 2 x 16GB 6000MHz
1 TB M.2 2280 PCIe
Cooler Master V850 SFX Gold
Windows Home
Full PC
NR2 Pro i7/4070 Super
Z790I WIFI DDR5
GeForce RTX 4070 Super 12GB
1 TB M.2 2280 PCIe
Windows Home
Full PC
NR2 Pro i7 / 4080 super
Z790I WIFI DDR5
GeForce RTX 4080 Super - 32GB DDR5
Cooler Master NR2 Pro
32GB DDR5 6000MHz
1TB M.2 NVMe SSD
Windows 11
Full PC
NR2 Pro i9/4070ti
Z790I WIFI DDR5
Intel Core i9-14900K
GeForce RTX 4070 Ti Super
64GB of 5600 Hz DDR5 RAM
2 TB M.2 2280 PCIe
Windows Home
full PC
NR2 Pro i9/4080 Super
Z790I WIFI DDR5
GeForce RTX 4080 Super 16GB
2 TB M.2 2280 PCIe
Windows Home
