More Balance, More Burst
Mobius 120 OC
Ring Blade Design
Fan Speed Toggle
Metal Motor Hub
Double Ball Bearing
Lifetime Warranty
Premium Anti-Vibration Dampers
$34.99
$39.99
-13%
productFree shipping over $100
PERFECTING ENGINEERING
Cooler Master has expanded on the Mobius Series performance fans with the new flagship model, Mobius 120 OC. The Mobius 120 OC features premium design and materials to deliver unprecedented quiet cooling performance. The upgraded Double Ball Bearing and metal motor hub guarantee high performance up to speeds of 3200rpm. We give you performance you can be confident in, and back it up with our lifetime warranty. Switch your experience into overdrive with the Mobius 120 OC.
RING BLADE DESIGN
FAN SPEED TOGGLE
Integrated fan speeds toggle built into the cable let you conveniently adjust fan speeds from 1500rpm up to 3200rpm.
DOUBLE BALL BEARING
Double Ball Bearings reduces friction to a minimum for silence and extended lifespan.
PREMIUM
ANTI-VIBRATION DAMPERS
Patented corner mount design dampen vibration and rattling while maintaining chassis stability for silent operation.
METAL MOTOR HUB
Motor hub constructed of metal for additional stability and reinforcement for extended superior fan performance.
LIFETIME WARRANTY
Premium materials and superior engineering provide incredible fan lifespan – backed by Cooler Master’s lifetime warranty.
