Limited edition
Lightweight Prestige
MM712 LINE FRIENDS minini Edition
The MM712 is the next evolution of our first popular lightweight mouse, leveled up to lightweight prestige.
NVIDIA® Reflex
NVIDIA Reflex is a revolutionary suite of technologies that optimize and measure system latency to deliver the ultimate competitive advantage. Gaming mice with NVIDIA Reflex when paired with NVIDIA G-SYNC Displays provide the only system latency measurement tool that detects incoming mouse clicks and measures the time for the resulting pixels (gun muzzle flash) to change on screen. Start every match with confidence, knowing your PC is operating at the lowest possible system latency.
An Optical Upgrade
We don’t believe in level caps. So if we’re going to upgrade the look, we might as well upgrade the hardware too. The MM712 is outfitted with the latest pro-grade optical sensor, adjustable up to 19,000 DPI for superior responsiveness and accuracy — improved even further from our already awesome MM711.
Unchain Your Mouse
When you’re mowing down infantry, you should never feel like you’re a cute widdle baby on a leash. That’s why for those traditionalists out there that ride-or-die on the cable, we’ve outfitted the MM712 with our Ultraweave Cable. Engineered in-house and composed of durable yet lightweight fiber, the cable doesn’t pull your way through the map, and doesn’t make precision aiming a pain. You might as well dump your mouse bungies now.
Make Real-time Adjustments On-the-fly
Changing your real-life loadout is easier than ever thanks to our On-the-Fly system. Adjust your DPI in real time and create new keybinds and macros with the simple press of a button combo.
Cooler Master’s second run of limited LINE FRIENDS minini Edition peripherals includes some of our most popular peripherals released this past year. This includes the CK721 mechanical keyboard, the MM712 lightweight mouse, and the MP511 XL mousepad — all adorned in a beautiful striking pink colorway. And did we mention limited edition? Get them before they’re gone forever!
