![](https://a.storyblok.com/f/281110/1920x680/9b224d1b3b/hyper-212-spetrum-v3-block4-bg-1-bannerdesktop.png/m/1700x0/smart)
Hyper 212 Spectrum V3
ARGB Auto Detection
Nickel Plated Heat Pipes
Wide Range Compatibility
Upgraded Installation Brackets
Cooler Master is releasing the Hyper 212 Spectrum V3, a redesigned addition to its popular 212 Spectrum predecessor.
ARGB Auto Detection
Intuitive LED detection automatically provides default ARGB spectrum lighting or full ARGB customization via 3-pin header connection.
Performance spectrum fan with ARGB compatibility with Asus Aura, ASRock RGB, Gigabyte and MSI RGB motherboards.
4 heat pipes with silver nickel plated finish provide exceptional cooling and aesthetics
Redesigned brackets simplify installation on the latest available platforms
