Brilliant ARGB Lighting
"Enhanced white frosted fan blades allows for more vibrant light dispersion, giving your build that spectacular brightness to go with the gaming feel.
![](https://a.storyblok.com/f/281110/900x400/bcc5be1c0c/hyper-212-argb-02-03-banner-01.png/m/845x0/smart)
The acclaimed Hyper 212 has been complemented with a vibrant ARGB feature. The Hyper 212 ARGB not only provides the best balance for cooling performance with the SickeFlow 120 ARGB fan, but also brightens up your build with eye-catching lighting. The addressable RGB fan is compatible with an array of certified motherboards. Utilizing exclusive Direct Contact Technology and 4 heat pipe arrangement the contact surface provides effective cooling and heat dissipation capable of handling elevated temperatures. The Hyper 212 ARGB is the distinct performance we all know with an equally striking display.
Redesigned curved blades and frame optimizes airflow and static pressure with customizable lighting
Included Mini ARGB controller gives you versatility for your favorite color arrays.
Stacked fin array provides low airflow resistance allowing cooler air flow through the heatsink
Direct Contact Technology using 4 copper heat pipes deliver exceptional heat dissipation
