GD120 ARGB Gaming Desk
The Essential Core of Your Setup
A sturdy workhorse with built-in ambient ARGB lighting, perfect for those with limited workspace. Whether you're battling foes on the battlefield or tackling spreadsheets and work-related tasks, the GD120 ARGB Gaming Desk has all the features you need.
The Smart Solution for Limited Work and Play Space
Standing just 120cm wide, the GD120 ARGB is compact enough to fit into your setup while still maintaining ergonomic features and extras such as ambient ARGB lighting.
SMART AMBIENT LIGHTING
Control your ARGB lighting with the MasterPlus+ app. The GD120 ARGB can be synchronized with display colors, mimic monitor visual in real time as well as other Cooler Master products.
No More Tangled Wires
The rear steel tray on GD120 ARGB is designed to help keep your cables and adapters neatly organized and out of sight, contributing to a clutter-free workspace. With this effective cable management solution, you can enjoy a more streamlined and efficient setup, making cable organization and accessibility easier than ever before.
Comfortable Ergonomic Workstation
The GD120 ARGB is thoroughly tested for durability, being able to withstand up to 100kg without breaking a sweat. Rest easy with this battle-tested table as your sturdy companion.
Additional Mousepad Included
Outfit your workstation with the included 900 x 300 mm mousepad with an anti-slip rubber base. Using water repellent* materials and anti-fray stitching, it's a worthy companion to your desk for long extended game or work sessions.
*water resistance is only for cold liquids, hot liquids may still absorb into the mat.
See More GD Series Gaming Desk
