Dyn X Turnkey Package 1
All-Around Professional Racing Simulator
Embrace a new dimension of sim racing with the Dyn X from Cooler Master. This isn't your everyday setup; it's a rigorously designed system for passionate racing enthusiasts who relish the thrill of the track in both real and virtual worlds. The Dyn X is engineered to fuel your need for speed and revolutionize your professional simulation environment.
Racing Cockpit
PRECISION-ENGINEERED FOR A GENUINELY AUTHENTIC RACING EXPERIENCE
The Dyn X exemplifies Cooler Master's commitment to innovation, marrying form and function in a sleek package. This is more than just a gaming rig—it's a pro-level racing simulator that invites you to experience real-to-life immersion at its finest. Step into the Dyn X and feel the pulse of professional racing from the comfort of your own home.
Frame
UNRIVALED FLEXIBILITY
One single adjustment offers 14 diverse driving positions: Formula, GT, Rally, Stock Car, Off-Road, Semi Truck, and more. The Dyn X adapts to your personal simulation needs.
Seat
LONG-LASTING COMFORT
Feel Every Track Detail
With larger motors and actuators, our motion system supports more weight and delivers a powerful, torque-enhanced feel, making it ideal for commercial applications. As a highly reliable, industrial-grade system, it offers exceptionally realistic vehicle motion feedback through advanced signal processing. Experience every elevation change, vehicle movement, surface change, and gear shift with unparalleled fidelity.
Motion
PROFESSIONAL MOTION SYSTEM
Provide exceptionally realistic vehicle motion feedback.
Motion Actuators
DYN X ACTUATOR MOUNT FEATURE
Haptic Feedback
Broad Compatibility
Electronic Mounting Tray
Simple And Easy Installation
DYNAMIC ACTUATOR TRAVEL
Features 2“ (50mm) of possible travel.
RUGGED CONSTRUCTION
The actuators feature a robust machined billet aluminum housing that are built to last.
LARGE WEIGHT CAPACITY
Supports up to 800 lbs (363 kg)
Envision Conquering Your Competition
Our latest high-performance curved monitor is made to immerse you in whatever visual experience you choose with an emphasis on detail at high frame rates. With VA mini-LED tech and dual 4k resolution, it's perfect for intense racing, extreme gaming and any action-packed movie.
Display
SRC STANDALONE MONITOR
Featuring a 57" screen with 1000R curve, 1ms response time, 120Hz refresh rate, and extensive color support, including DCI-P3 at 98% this monitor can be your go-to for any application. And it's built-in KVM switch helps you flip from laptop, desktop or console in a flash.
Monitor
WRAP YOURSELF IN ADVENTURE
Experience the next level of heart-pounding gaming with even more intensity as the vivid scenes wrap around you.
Monitor Mount
VARIO VESA ADAPTER KIT
Monitor Stand
FREE-STANDING
This is a Free-Standing Monitor Stand that can support TVs (Up to 65") or Ultrawide Monitors (Up to 57")
Advanced High Torque Motor
Delivers up to 25 Nm of force, ensuring deep immersion across various racing scenarios.
Steering Wheel Base
STEERING REALISM, REDEFINED
The Cooler Master x Simucube 2 Pro Co-brand Direct Drive Wheelbase represents a new cutting-edge advancement in sim racing gear designed for elite racers and dedicated enthusiasts.
The Cooler Master x Simucube 2 Pro Wheelbase revolutionizes the racing simulation experience with its unparalleled precision and immersive force feedback, driven by a high-torque, brushless motor.
Engineered for excellence, this wheelbase redefines expectations, offering an unmatched level of realism and engagement in the virtual racing world.
Steering Wheel
CUBE CONTROLS F-PRO
Steering Wheel Quick Release
SIMUCUBE QUICK RELEASE WHEEL SIDE KIT
Used for attaching your steering wheel to a Simucube 2 wheelbase.
Pedal Set
HEUSINKVELD ULTIMATE+ PEDALS NO CLUTCH
A strong, durable and adjustable design capable of handling up to 140kg of actual force at the brake pedal (200kg loadcell).
Baseplate
HEUSINKVELD ULTIMATE+ BASEPLATE
If you want to mount your pedals to a baseplate first instead of mounting them individually to your rig, our Sim Pedals Ultimate+ Baseplate is your product of choice.
NR W9
Powered by an Intel® Core™ i9 processor and the NVIDIA® GeForce RTX™ 4080 SUPER this system is truly a workhorse.
Mini PC
NR W9
Editors, designers, and gaming enthusiasts can capture and manage footage with the robust Cooler Master NR W9 Workstation Computer. Sporting a reduced size, the NR W9 features ample connectivity and powerful components while saving space in your work area without sacrificing performance.
Peripherals
COOLER MASTER PERIPHERALS
Audio
COOLER MASTER HEADSET
SOUND BLASTERX AE-5 PLUS PURE EDITION
Networking
PCIE NETWORK CARD
Frame Accessories
Cooler Master's reputation for quality and innovation extends to our accessories, giving you confidence in every component you add to your system.
Frame Accessories
COOLER MASTER CUSTOM FABRICATION
Seat Slider
Steering Adjuster
Floor
Pedal Slider
Power Distribution
EQUIPMENT RACK 8U
Power Distribution
POWER CONDITIONER & SURGE PROTECTOR
Cables
CABLES
10ft USB Extender
15ft USB Cable
10ft Headphone Extension Cable
15ft Monitor Cable (HDMI)
15ft IEC Power Cable (14AWG)
Cable Management
Cable Management
6.6 ft 1.5“ Split Sleeve Wire Loom
25 ft 1“ Split Sleeve Wire Loom
12 ft x 3/4“ Velcro
Purple-Glove Service
Our purple-glove assembly service goes beyond standard delivery. Our skilled technicians will carefully unpack, assemble, and install your items, ensuring they're perfectly set up and ready to use.
DELIVERY
Premium service involving careful handling, assembly, and even removal of packaging materials.
*Prices are subject to change depending on location and accessibility of desired location.
ASSEMBLY
SOFTWARE CONFIGURATION
Our experienced technicians will handle the entire setup process, ensuring your software is correctly installed, configured, and optimized for peak performance.
ON-SITE TRAINING
Our on-site experts will guide you through every step of your racing simulator setup, ensuring optimal performance and a truly immersive experience.
CUSTOMER SUPPORT
WARRANTY
We stand behind the quality of our hardware with a 1-year limited warranty. If your product experiences any defects in materials or workmanship under normal use within one year of purchase, we will repair or replace it at our discretion. This warranty does not cover damage caused by accidents, misuse, or unauthorized modifications.
