Quiet Colorful Cooling
CF120 ARGB
Air Balance Fan Blades
Noise Minimization
Addressable RGB Lighting
$39.99
productFree shipping over $100
CF 120 ARGB
Cooler Master’s CF120 ARGB is the most well rounded fan solution for your case and chassis. The frame is constructed with reinforced PBT for stability, with air balance fan blades for high airflow and cooling performance. The flexible mounting system is anti-resonance for noise minimization. The CF120 ARGB is cost effective case fan for excellent cooling capabilities while also giving you vibrant ARGB lighting to add the touch of color to your build.
Air Balance
Fan Blades
Noise
Minimization
Vibrant ARGB lighting to add the touch of color to your build, Compatible with major Motherboards.
Trending
GX Gold 850 Full Modular
GX Gold 850
80 Plus Gold Certified ATX Power Supply Unit
GX Gold 750 Full Modular
GX Gold 750
GX Gold 650 Full Modular
GX Gold 650
HAF 700
The Berserker
