Cooler Master Unveils the Ncore 100 Air: Compact Design Made for Easy PC Building and Upgrades
Space-Saving Design Meets High Performance in a Sleek, Minimalistic Form Factor
Summary
TAIPEI, TaiwanJanuary 7, 2025 — Cooler Master, a global leader in PC components and tech lifestyle solutions, today announced the Ncore 100 Air, a small form factor (SFF) PC case crafted for gamers, content creators, and SFF enthusiasts. Designed to streamline PC building and upgrading, the Ncore 100 Air features an open, tool-less design, an innovative expandable design and compatibility with the latest hardware, ensuring users can easily keep up with their performance needs while enjoying a sleek, minimalistic look.
The Ncore 100 Air builds on Cooler Master’s commitment to empowering users to create high-performance PCs in small spaces. Designed with modern users in mind, this case delivers the perfect blend of power, versatility, and minimalism, supporting the latest GPUs, ITX motherboards, and SFX power supply units while maintaining an efficient thermal layout.
“The Ncore 100 Air is more than just a PC case; it’s a statement for builders who value simplicity, performance, and style,” said Jimmy Sha, Cooler Master CEO. “We designed this product to meet the needs of gamers and creators who want powerful hardware in a compact, elegant form. With its open frame and innovative features, the Ncore 100 Air reflects our mission to empower users with products that are as versatile as they are sophisticated.”
Features
• Ultra-Small Footprint: Compact 14.7L size, comparable to a small booklet.
Open and Tool-less Design: Easy-to-access frame with tool-less design for quick builds and upgrades.
Superior Airflow: Large mesh air vents and efficient thermal layout for optimized cooling.
Hardware Compatibility: Supports triple-slot GPUs up to 336 mm (extendable to 356 mm) and Intel/AMD ITX motherboards.
Premium Build: Anodized aluminum panels in black or white for a sleek, minimalistic aesthetic.
Pre-Installed Cooler Master Low-Profile Fan: Ensures efficient airflow right out of the box.
Dimensions: Standard: 155 mm x 212 mm x 449 mm; Expanded: 172 mm x 212 mm x 449 mm.
Connectivity: Includes USB Type-A and Type-C ports and an audio combo plug.
Availability and Launch Details
The Ncore 100 Air will make its debut at Cooler Master's exhibition in Las Vegas and will be available globally starting in the first quarter of 2025 through Cooler Master’s retail partners, Amazon, and the Cooler Master online store. Discover more about the Ncore 100 Air at: https://www.coolermaster.com/en-global/products/ncore-100-air/.
About Cooler Master
