360 DEGREES OF COOL
CREATED ONLY FOR THE BEST
PRECISE SILENT POWER
RELAXATION AT YOUR COMMAND
COOL. COMPACT. QUIET.
PSU Calculator
CPU Compatibility
Guide & Resources
Product registration
Tech support
Warranty
Warranty check
Faq
Contact us
Special Announcement
• Semi-Fanless up till 15% load
• Dual Forward and DC-to-DC circuit design
• 5 years warranty
• More Conductive PCI-e Cables
• 80 PLUS Bronze Certified
• Durable LDB bearing
The Berserker
The page you're looking shows Cooler Master contents for Singapore.Are you sure you want to continue browsing the current site?
