Bring On The Light
MasterFan MF140 HALO²
Cooler Master has redesigned our Dual Loop LED series fan to introduce the new MasterFan MF140 Halo².
A DUAL NEW WORLD
The MasterFan MF140 Halo² is our redesigned dual loop LED series fan. The MF140 features 10% larger fan blades for improved air flow and cooling performance. The frame has been designed with a hybrid structure that maintains stability without sacrificing operational real estate. An upgraded driver IC is also included for increased cooling performance and minimal fan noise, while the elegant dual loop LED design is maintained via addressable gen 2 RGB lighting that provides the ultimate customizable experience. Enter a dual new world with the MasterFan MF140 Halo².
HYBRID FRAME DESIGN
A hybrid frame structure maintains stability without sacrificing fan blade size or performance.
UPGRADED DRIVER IC
An upgraded driver IC boosts cooling performance while minimizing fan noise.
