VIBRANT ADDRESSABLE GEN 2 RGB
50% MORE LIGHTNING
Larger LED rings increase lighting by 50% for even more vibrant lighting.
Cooler Master has redesigned our Dual Loop LED series fan to introduce the new MasterFan MF120 Halo².
Redesigned frame structure and corner dampers maintain stability without sacrificing fan blade area for better performance.
Air Balance fan blades increased by 10% in size deliver stronger air flow and cooling performance.
Fine tuned P-Q Curve increase air flow and pressure while being even more quiet than its predecessor.
The page you're looking shows Cooler Master contents for Singapore.
