MasterBox TD500 Mesh V2
MasterBox TD500 Mesh V2’s iconic polygonal design keeps your system looking unique and your gaming sessions streamlined.
Design
FINEMESH PERFORMANCE FRONT PANEL
Polygonal FineMesh features a 3D contour and is also capable of simultaneously providing high airflow and dust filtration.
Colors
AVAILABLE IN BOTH BLACK & WHITE
Our Achievements
7 AWARDS
Fans
THREE CF120 ARGB FANS INCLUDED
Pre-installed CF120 ARGB fans provide ample airflow, ensuring low temperatures, high performance, and eye-catching aesthetics during even the most intense gaming sessions.
Ports & Slots
USB 3.2 GEN 2 Type C Support
USB 3.2 Gen 2 Type C port built into the 1/0 panel allows multi-purpose, streamlined data transmission.
REMOVABLE TOP PANEL
The top panel is entirely removable for improved access during assembly and ease of mounting of cooling solutions.
Motherboard
Hardware Compatibility
MasterBox TD500Mesh V2 is natively compatible with ITX, M-ATX and ATX motherboards.
E-ATX motherboards, such as SSI-CEB models, are compatible with dimensions up to 12" x 10.7".
Customization
VERSATILE COOLING OPTIONS
Support for up to seven 120mm fans and 60mm front and top radiator support nsure that performance is not ompromised.
TOOL-FREE CRYSTALLINE TG SIDE PANEL
Featuring a crystalline tempered glass side panel, completely toolless for quick access to the internals.
PSU SHROUD WITH REMOVABLE COVER
MasterBox TD500 Mesh V2's removable PSU cover allows users to freely decide whether to showcase or keep their PSUs hidden.
ARGB/FAN HUB Included
The included controller allows users to manage systems lighting independently from the hardware configuration and provides the user with 4 additional fan headers in case of need.
