Strong Airflow Low Noise
I50 for LGA 1700
I50 for LGA 1700 CPU Cooler
STANDARD COOLER I50
I50 is a newly designed air cooler that compatible with intel LGA 1700 sockets. 60.8mm super thin design perfectly fits All-in-One systems or limited form factor cases. Aluminum fins provide excellent heat dissipation. 92mm diameter fan with long life expectancy, durable materials, strong airflow, and low noise output.
26.8
dBA
max.
40.87
CFM
INTEL
LGA 1700 COMPATIBILITY
