Full Modular 80 PLUS Platinum Power Supply with Smart Thermal Control Mode
XG750 Platinum
• Intel ATX 12V Ver. 3.1
• 80 PLUS Platinum & Cybenetics Platinum certifications
• Cybenetics A++ noise level certification
• Quiet 135mm Fan
• Smart Thermal Control Mode with Hybrid Switch
• Full-Modular Cabling
• 10-Year Warranty
XG750 Platinum
FULL MODULAR 80 PLUS PLATINUM POWER SUPPLY WITH SMART THERMAL CONTROL MODE
•Cybenetics A++ noise level certification
• Quiet 135mm Fan
• 10-Year Warranty
Silence is Platinum
With a focus on thermal dissipation and maximized efficiency, this platform allows Cooler Master to offer an entirely new class of high efficiency products with 100% Japanese capacitors, boasting top-shelf performance with reduced ripple noise.
First In-house Design Platform
Cooler Master keeps searching for uniqueness, creativity, and more. XG Plus Platinum is the first Cooler Master in-house designed power supply, providing next-level efficiency, rigid design, and sturdy performance to fulfill all your daily computing and gaming needs.
Crafted For Excellence
This professional grade power supply unit is built with full-bridge LLC resonant converter and DC-DC technology, made for the all users providing stability, reliability and so much more.
A - High permeability PFC inductors, improve power factor
B - All-Japan capacitor, make XG have longer life
C - LLC Topology makes XG more Efficient
D - Uniquely designed transformer with lower heat
E - High-performance synchronous rectification
F - DC to DC Converter
Silence is Platinum
XG750 Platinum has been certified by Cybenetics for both Platinum efficiency and an A++ noise level. It delivers over 92% efficiency at typical loads and maintains an average noise level below 15dB(A) through its smart thermal control system.
Fan Up, Fan Down
Both side panels on the XG Platinum are embossed with a stylish silk screen printed design. Install your PSU in either a fan up or fan down orientation while retaining 100% of the unit's aesthetic value anytime, anywhere.
Build Your Way
Every facet of the XG Platinum was chosen with the goal of maximizing efficiency and thermal performance. Full modular cables were a must so that users could minimize the number of cables in their system based on their needs, reducing clutter and increasing both airflow and aesthetic quality.
Built to Last
With a 10 years warranty, you’ll be using this longer than most up to date home consoles and most of the other components in your system.
PSU Calculator
Try out our easy to use, comprehensive PSU calculator.
