New
Industrial Leading SFX Power Supply
V SFX Platinum 1300 230V ATX 3.1 White Edition
• High Power Density
• Fully support ATX 3.1
• 100% Japanese Capacitors
• Full-bridge LLC and DC-DC technology
• Fully Modular Cables
• 10-year Warranty
A Revolution To SFX
Leading the SFX power supply industry, the V SFX Platinum delivers not only the most powerful SFX power supply but fully compatable with ATX 3.1, both ITX and ATX cases, bringing a revolution to SFX power supply.
High Power Density
Adopting with the components miniaturization technology by the improvement of materials engineering, manufacturing process and leading thermal technology, the V SFX Platinum has achieved one of the highest power density, 30% more than V SFX Gold 850W power supply, in the small form factor.
Miniaturized But Solid
Crafted with flat copper wire on Choke of DC-DC, flat transformer piling and aluminum plate dissipation structure on full-bridge LLC, it can effectively achieve components miniaturization. Adopting with advanced manufacturing process, it simultaneously keeps miniaturized but solid.
Full & Flexible Compatibility
Designed to fully support ATX 3.1 and provide backward compatibility, supporting both RTX 40 and 30 series graphics cards, and alongside with included bracket to support both ITX and ATX cases, the V SFX Platinum offers a PSU with the most complete compatibility.
Enhanced Dissipation
With the integration of transformer and rectifier, full-bridge LLC heat dissipation structure, and the EMI-inhibited amorphous metal materials, the V SFX Platinum provideds advanced performance and heat dissipation.
ATX 3.1 Support & A Durable 90-Degree 12V-2x6 Cable
Includes ATX 3.1 support and a 90-degree 12+4 pin (12V-2x6) PCIe 5.1 connector featuring higher electrical durability and improved safety, capable of bringing up to 600W to your GPU*.
Fully Modular Cabling
Modular cables reduce clutter, increase airflow, and improve overall efficiency and thermal performance.
