THRONE X
THRONE X
A Multi-Purpose, Immersive Stool for Musicians
Blending sound-to-vibration technology with musical arts, the Throne X provides a new level of interaction between musicians and their instruments, fellow musicians, and the broader environment. It creates a unique way for musicians to control the rhythm and therefore to master their performances.
Sitting on the Throne X, musicians can feel the rhythm pulsing through their bodies, intuitively performing on the beat, better synchronizing with their bandmates, and immersing themselves in the art of music.
Metronome
The Throne X, a multi-purpose immersive stool designed for musicians, provides a tactile experience that enables one to physically feel the tempo. Moreover, being the industry’s first musician stool to actively provide vibrations even without input, the Throne X can serve as a metronome for musicians to improve their skills, both during practice and performance.
Immersive performance
Multi-use
The multi-mode functionality provides unique settings for several use cases. In audio mode, the stool vibrates based on musical input or the rhythm of your bandmates. In metronome mode, the stool helps you keep the beat. In real-time mode, the stool vibrates to the rhythm of your performance.
User-friendly
Perfect companion to artists on-the-go
A foldable stand and a backpack for storing the stool makes travel easier for touring musicians.
Long-lasting comfort
Sleek, Modern Design
A contemporary exterior design presents a smart tech appearance, adding a touch of modern sophistication to your daily life.
Convenient, Lag-Free Controller
A built-in wired controller allows you to easily change mode, adjust speed and tempo, and modify vibration intensity.
Seamlessly Integrate with PA Systems
With easy PA integration, you can easily synchronize with other performers and create a more immersive stage experience.
Solid Construction
A well-structured frame and support delivers high durability and withstands prolonged hours of vibrations.
EXTENSIVE COMPATABILITY
The Throne X includes inputs for 3.5mm aux, 6.3mm aux, 6.3mm dynamic microphone, and 3.5mm headphones.
TWO-STAGE HEIGHT ADJUSTABLE
The standard fixed stand offers advanced comfort and options for different heights to meet your needs.
SELF-CENTERING
Designed with self-aligning torque, the seat always returns to center position after musician stands up even if the seat has been turned during use.
Trending
GX Gold 850 Full Modular
GX Gold 850
80 Plus Gold Certified ATX Power Supply Unit
GX Gold 750 Full Modular
GX Gold 750
GX Gold 650 Full Modular
GX Gold 650
HAF 700
The Berserker
