RECALL USERS' PASSION FOR PC DIY
The TD500 MAX, Cooler Master's first AT case in the MAX series, features a preinstalled customized AlO cooler, GXII Gold 850W ATX 3.0 PSU, patented 2-stage cable connectors, and a screw storage pad. It aims to revive users' passion for PC building while reducing the challenges faced putting together high-end PCs.
2 AWARDS
38MM
THICKER RADIATOR
OUR EXCLUSIVE DESIGN IS BEVOND EASY
The TD500 MAX streamlines PC building by pre-connecting the GXII
PSU with 2-stage Cable Connectors and providing a screw storage
pad under the PSU Cover. This allows quick and elegant builds, with
the added convenience of replacing the motherboard without opening
the back panel.
