PL360 SPR Edition
Sapphire Rapids LGA 4677 compatible, Large, full-coverage copper base, Industrial-grade structural design, Double impeller pump, Mobius 120 fans
Certified by INTEL
Introducing Cooler Master’s PL240/360 SPR Edition, our new cooling workhorse designed to power through the toughest tasks you will tackle in your day to day, in tandem with Intel’s latest Xeon Platinum Processor. The PL240/360 hhas been designed specifically for the Xeon and is Intel-certified to be exclusively compatible with its LGA 4677 sockets. Power up your workstation with the ultimate cooler-processor duo.
An extra-large copper base ensures rapid heat transfer while a double impeller brings more powerful water flow for quick heat dissipation to ensure your workflow is never interrupted.
Industrial-grade structural design provides a fully sealed chamber and totally stable operation, for whisper quiet operation that won’t distract or derail your productivity.
Double Impeller
A double impeller strengthens water flow, again reinforcing heat dissipation for that extra cooling oomph when you’re pushing your machine to the limits with multiple applications and complex tasks.
Larger Surface Area
Expanded radiator fin surfaces accelerate cooling, perfect for the expanded power of the Xeon.
Mobius 120 Fans
Our critically acclaimed Mobius 120 fans can’t be beat in the realm of whisper-quiet cooling power, and here they provide the final step in an all-encompassing cooling package.
CPU COMPATIBILITY
