LATEST GEN GPU COMPATIBILITY
Supports triple-slot graphics cards up to 336 mm in length. The PCIe slot is adjustable to accommodate cards up to 356 mm, ensuring compatibility with the latest-generation GPUs.
EFFICIENT THERMAL LAYOUT
The Ncore 100 Air layout has been meticulously designed to offer the most efficient thermal layout. This layout pulls in air from the standing sides of the case, which are its largest surface.
