Flash Sale
Masterliquid ML360 SUB-ZERO EVO
New Compact DIY Pump
Redesigned TEC Unit
Ambient Sealing Fence
Addressable Gen 2 RGB
New Mobius 120 ARGB Fans
THE CHILLED CHAMPION
Cooler Master has redesigned the innovative Thermoelectric Cooling (TEC) solution with the launch of the new MasterLiquid ML360 SUB-ZERO EVO. In collaboration with Intel® Cooler Master has developed an AIO to attain sub-ambient cooling in combination with Intel® Cryo Cooling Technology, creating the ultimate AIO Liquid Cooler that delivers the best cooling performance for Intel’s performance CPUs.
Powered by Intel® Cryo Cooling Technology with integrated software to allow customizable overclocking catered to your specific needs.
The redesigned TEC unit within the water block accelerates cooling to deliver maximum overclocking of your Intel® processor.
Low Profile Radiator
Low profile radiator with superior fin density coupled with performance fans dissipates heat rapidly.
NEW DIY PUMP
Compact DIY pump upgraded with silent IC delivers better noise performance with small footprint.
SETTING UP OVERCLOCKING ON YOUR CPU
Overclocking your CPU doesn’t have to be complicated and can be achieved in 2 basic ways: Overclocking through BIOS Settings OR Using Intel XTU Software (For more info on downloading and setting up XTU software, click the link below)
NEW MOBIUS FANS
Acclaimed Mobius Series fans optimized for both performance and acoustics to cater to all demands from case, liquid or air cooling for gaming & overclocking.
CPU COMPATIBILITY
