Big Possibilities, Small Size
MasterBox NR200P V2
Compact yet powerful
Stay cool under pressure
Optimized GPU performance
Comprehensive GPU support
Easy, tool-free access
USB 3.2 Gen 2x2 Type C support
Refreshed NCORE style
Cooling System
240-280MM
LIQUID COOLERS
18.25L
ULTRA-SLEEK DESIGN
Extra Cool
120MM
BOTTOM FAN
COMPREHENSIVE GPU SUPPORT
Includes vertical mounting options, a custom PCle 4.0 riser cable, and a support bracket for GPUs up to 356mm in length and 160mm in height.
USB 3.2 gen 2x2 Type C support
A USB 3.2 Gen 2x2 Type C port is built into the 1/0 panel with up to 20Gbps transfer speeds.
All external panels are secured with pins for easy removal, facilitating quick access to the internals without the use of tools while a removable GPU panel simplified the installation process.
The new NCORE Style
An NCORE redesign provides a sleek take on maximizing cooling performance and style simultaneously.
Build Small. Play Big.
This case is compatible with SFF-Ready Enthusiast GeForce cards, so you can pack high performance into a smaller footprint. Look for SFF-Ready Enthusiast GeForce Cards to get a sure fit and streamline your PC build.
Trending
GX Gold 850 Full Modular
GX Gold 850
80 Plus Gold Certified ATX Power Supply Unit
GX Gold 750 Full Modular
GX Gold 750
GX Gold 650 Full Modular
GX Gold 650
HAF 700
The Berserker
