Mesh Front Panel
Large filtered intakes promotes high airflow, keeping internal components
running at optimal temperature
4 Awards
GPU
120mm fan
Dual 200mm ARGB fans
Iconic 200mm ARGB fans embedded in the core of the HAF Series
in design and function move high volumes of air quietly and effectively
due to their large size. Utilizing the included hub, ARGB lighting can be
customized to create a comprehensive theme to match your build.
