Ergonomic Design
5 ergonomic height settings make sure you are always able to choose the right height for your viewing angle.
Full Mesh Board
The use of full mesh board improves its cooling performance greatly.
Led Strip & Additional USB Hub
A blue LED strip helps you find the right keys on your keyboard and 4 additional USB ports give you all the flexibility to connect your devices.
Silent Cooling
A 140mm fan, designed for silence, keeps you laptop cool and working smoothly.
