New
Close Cold Contact
CryoFuze 7
Noncorrosive Formula
Low Thermal Impedance
Anhygroscopic Composition
Eco-Friendly Packaging
Thermal grease CryoFuze 7
Introducing CryoFuze 7, our all-new line of thermal pastes. Available in both 2g and 4g amounts, CryoFuze 7 utilizes nanoparticles to allow for excellent thermal conductivity and heat transfer on all processing components.
High Performance
Utilizing nanoparticles, CryoFuze allows for excellent thermal conductivity on all processing components for optimal heat transfer.
low thermal impedance
With thermal impedance of 0.03C*cm2/w, CryoFuze 7 greatly improves overall performance
Non Corrosive Formula
CryoFuze 7 also has a versatile range of temperature performance, maintaining stability from -50°C up to 250°C. All of this is contained in an eco-friendly, environment-first package.
Easy Application
Viscously balanced formula allow for easy application and clean up.
ECO-FRIENDLY PACKAGING
Designed with the environment in mind, CryoFuze 7’s packaging reduces waste
