New
Let in the Cold
Cryofuze 5 20g
High performance
Purple Tinted Compound
Low thermal impedance
Non-corrosive formula
Volume 20g
CRYOFUZE 5 THERMAL GREASE
With the successful launch of CryoFuze 5, Cooler Master provides a large capacity of 20g for extensive use, ideal for multiple applications.
LOW THERMAL IMPEDANCE
Low thermal impedance greatly improves performance, while a balanced viscosity and electrically insulated composition delivers exceptional bounding with effortless application and clean up.
LINT-FREE CLOTHS SWAB
Cleaning surfaces before applying thermal paste helps ensure optimal performance
NON-CORROSIVE FORMULA
CryoFuze 5 is non-corrosive and resistant to oxidation, leaving contact surfaces unharmed and preventing solidification.
PURPLE TINTED COMPOUND
Purple tinted thermal compound utilizes a superior composition capable of maintaing stability from -50°C up to 240°C
HIGH PERFORMANCE
Exceptional thermal conductivity improves even the most extreme system builds.
ECO-FRIENDLY PACKAGING
Designed with the environment in mind, CryoFuze 5’s packaging reduces waste
