Legacy Continued
Continuing the legacy of the Caliber R2 Gaming Chair, the Caliber R3 offers a a brand new design with improved comfort and ergonomics.
Perfect For Any Scenario
Designed specifically for those who spend extensive amount of hours staying seated for work as well as play, the Caliber R3's clean, professional aesthetic with a full array of ergonomic features makes it the perfect addition to your setup.
Choose Your Style
Caliber R3 is available in your choice of purple or black colorways.
Ergonomics That Adapt to You
Caliber R3's ergonomics have been entirely upgraded. Featuring a larger headrest and lumbar support for an improved ergonomic fit for all users, the R3 is suitable for all body types and provides ample support where you need it most.
All-Day Comfort
Caliber R3 features ultra-soft yet dense memory foam that dynamically contours around you for all-day comfort.
Enhanced Seat Base
Caliber R3's seat base has been upgraded from a 9cm thick seat base to a 10.5cm. Increasing the thickness provides enhanced support and durability, ensuring comfort and support for even longer work or play sessions.
Upgraded Perforated Material
The Caliber R3 now features an all-new, fully blacked-out synthetic performance PU for the perforated patches, matching the high-quality PU leather used on other parts of the chair.
Recline The Way You Want
Caliber R3 continues to offer a 180° full-reclining experience.
Precision Class 4 Gas Lift
Caliber R3 uses the proven and tried Precision Class 4 Gas Lift for precise, reliable, height and lock adjustment.
2D Armrest
Caliber R3 features an adjustable 2D armrest to provide support where you need it most.
Reinforced Steel Frame Structure and Base
Caliber R3 continues to use a class-leading steel frame gauge and structural design to deliver a superior experience with durability lasting for many years to come.
Cooler Master Exclusive Design
Featuring a design and colorway unique to Cooler Master's own identity, Caliber R3 is an extremely stylish chair that is sure to blend seamlessly into your setup.
