Ergonomic Design
Freely adjust the sitting angle with the reclining backrest to find your perfect resting position. With a height-adjustable gas lift, the Caliber E1 helps to minimize fatigue and maximize the comfort of your gaming or work sessions.
The New Caliber E1 gaming chair brings you the comfort you need to thoroughly enjoy gaming and working. With all the necessary ergonomic adjustments along with a comfortable and breathable PU leather material, the E1 is a great value addition to your setup.
The headrest and lumbar pillow will provide you with the best level of comfort to reduce back pain and alleviate neck strain.
Caliber E1 features a design that is sleek and understated. For those who want a clean, simple aesthetic with minimal branding, the Caliber series gaming chairs are the perfect companion to your setup.
