Small, Simple, Versatile
LED Controller A1
Simple and Compact
Backwards Compatibility
MasterPlus+ software
€14.99
LED Controller A1
Cooler Master has engineered the new Addressable Gen 2 RGB LED Controller granting you the versatility to easily personalize your devices delivered to you in a small compact size.
Simple And Compact
No need to hassle with an ARGB capable motherboard or complex software. With 3 ARGB headers available, each header can connect up to 80 individual LEDs for a total of up to 240 LEDs.
A. 5V SATA Power Connector
B. 9 Pin USB Connector
C. 5V 3 Pin ARGB Connector
Compatible with both Gen 2 ARGB and standard ARGB devices, connect all your devices with the simple touch of a button.
New Addressable Gen 2 RGB
Addressable Gen 2 RGB controller works with Cooler Master's MasterPlus+ software, allowing you to customize each individual LED's color, effect, brightness, and more – all from an intuitive, convenient interface.
