Vertical Graphics Card Holder Kit V3
Supporting cases ranging in size from m-ATX to ATX, and featuring a removable adjustable GPU bracket, this remastered design allows unprecedented compatibility with various builds and setups. A PCIe 4.0 riser cable is included to assist the installation process and ensure high efficiency at uncompromised speeds.
Cooler Master Riser Cable PCIe 4.0 Included
Allows for efficient data transmission and connectivity
between the latest hardware components
Premium Materials
42%
Increased Durability
Compatibility
ATX & m-ATX Compatibility
Designed for both ATX and mATX cases, this accessory is compatible with the latest GPUs available on the market
GPU
EFFORTLESSLY SHOWCASE YOUR GRAPHICS CARD
Bring the best out of your components by showing off your GPU
Compatibility
Compatible with all Standard ATX Chassis
The newly revised Vertical Graphics Card Holder Kit fits all standard ATX chassis, now providing even more options for adjusting graphics card position.
Compatibility
...and all Standard M-ATX Chassis
Compatibility with m-ATX cases is guaranteed thanks to the brand new design that simply requires 4 PCi slots for installation.
GPU connection to external monitors is facilitated due to the modular design, now 100% adjustable according to preference and needs.
TOOLLESS, INSTANTLY ADJUSTABLE DESIGN
Adjustability
X AXIS
Adjustability
Z AXIS
Natively Compatible with "flow-through" GPU Coolers
The fully ventilated design is specially designed to allow unrestricted airflow for "flow-through" GPU coolers
