THE FUTURE STARTS NOW
This power supply unit contains a semi-digital platform. This allows you to connect the PSU directly to the motherboard via an included USB 3.0 cable.
Semi-Digital Platform
80 PLUS Gold Certified
Fully support ATX3.0
STCM (Smart Thermal Control Mode)
Fully Modular Cable Management
10 Year Warranty
An indispensable digital power supply in the digital age, in addition to its excellent hardware design and materials, coordinate MasterPlus+ the platform to let you manage power more effectively.
With the digital platform you can monitor performance in real time, tracking details such as fanspeed, temperature, and current load. You can even get readouts of performance data collected over time. Make the most of your PSU by taking control of it directly.
Compliant with ATX3.0 standard and 12VHPWR connector, the V Gold i can support the peak power up to 200% more than rated power.
