QUIETLY SUPREME
V Platinum 1600 V2
Dual 40 series​ GPU support
ATX 3.1 support & two durable 90° 12V-2x6 cables
Advanced heat dissipation
Ultra-quiet Mobius fan
80 Plus Platinum certification
12-year warranty
Quietly Supreme
V Platinum V2 delivers silent operation, featuring an ultra-quiet Mobius fan, a protective conformal coating heatsink, smart thermal control, zero-RPM fan mode, fully modular cabling, and 80 Plus Platinum efficiency, backed by a 12-year warranty.
Silent fan performance with a zero speed mode
Quietly Supreme
Purple anodic-coated heat sink with bevel cut lowers average temperatures, compared to traditional heat sinks. Bevel cuts bring out the heat source more effectively, and after concentrating the flow field, benefiting the heat dissipation.
*The temperature difference at fan standstill is 5.2 °C.
Mobius fan featuring a Ring Blade Design (RBD) for advanced heat dissipation
Certified Efficiency
An interleaved PFC decreases power loss and improves efficiency by minimizing current, reducing interference, and reducing output capacitor ripple current.
Two Durable 90° 12v-2x6 Cables & ATX 3.1 Support
Includes ATX 3.1 support and two 90° 12V-2x6 connectors featuring more reliability, higher electrical durability, improved safety, and the capacity to deliver up to 600W per connector, totaling an impressive 1200W output to empower your GPU.
Fully Modular Cabling
A modular cable management design reduces clutter, increases airflow, and improves overall efficiency as well as thermal performance.
PSU Calculator
