An improved fan blade provides higher fan speed, air pressure, and airflow while sticking to the same low noise level the SickleFlow is known for.
REDESIGNED FAN FRAME
The SickleFlow’s signature lines are now included in the frame design to provide a more cohesive product design.
IMPROVED BEARING SYSTEM
An enhanced loop dynamic bearing system keeps things running silently smooth.
SickleFlow Edge 120 ARGB comes with a mini controller to personalize the fan color and lighting effects. The mini controller is connected to the USB header on the motherboard and works seamlessly with Cooler Master’s MasterCTRL and MasterPLUS + software.
