Choose The Most
SickleFlow 120 ARGB White Edition 3 in 1
Continuing the SickleFlow 120 series , Cooler Master introduces a few new models with brand new upgraded design features for enhanced performance.
SickleFlow 120 ARGB White Edition, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
Enhanced Fan Frame
Sealed Bearing Structure
New Blade Design
Secure Connection
Includes Addressable RGB connector clips to ensure a secure connection
Addressable RGB Controller
With Included Addressable RGB Controller, You can choose your favorite color easily. It also support lighting RESET button of Case.
