New
MORE BALANCE, MORE BURST
Mobius 140 Black Edition
Ring Blade Design
Pressure Air Acceleration
Loop Dynamic Bearing
Dust Protection
Oil Reflow System
PERFECTING ENGINEERING
Introducing the Mobius 140 Black Edition, the latest addition to Cooler Master’s acclaimed Mobius case fan series. This version features all the high-performance elements of the classic Mobius, now in a sleek blackout design. With innovative ring blade design, loop dynamic bearing, oil reflow, anti-sway systems, and dust protection, the Mobius 140 Black Edition offers a stylish upgrade to a Cooler Master classic.
RING BLADE DESIGN (RBD)
ANTI-VIBRATION DAMPER
PRESSURE AIR ACCELERATION
Angled inner frame rim with chamfered side vents boost airflow draw, maximizing force induced air pressure and diminishing dead air.
LOOP DYNAMIC BEARING
OIL REFLOW SYSTEM
DUST PROOFING
ANTI-SWAY SYSTEM
