New
MasterLiquid Core II Series
Innovative design
Dual chamber pump
Optimum tubing length
Revamped fans
Updated CPU compatibility
Easy installation
Included Cryo-Fuze thermal paste
Building upon the success of the MasterLiquid series, Cooler Master presents the newly redesigned MasterLiquid Core II Series. Features such as a refined G9R dual chamber pump for silent performance and updated CPU compatibility for total build flexibility make the Core II a next level liquid cooler. With an infinity mirror design on the pump cover, overhauled and enhanced fans, and optimized tubes for easy installation, the Core II is the epitome of powerfully elegant design. Take the cooling power of your setup into the modern era with the MasterLiquid Core II Series.
3 x 120mm fans
MASTERLIQUID 360 CORE II
3 x 120mm fans
MASTERLIQUID 360 CORE II WHITE
2 x 120mm fans
MASTERLIQUID 240 CORE II
2 x 120mm fans
MASTERLIQUID 240 CORE II WHITE
Innovative Design
An infinity mirror pump cover gives the pump a stellar aesthetics
Dual Chamber Pump
Upgraded design resulting in a compact cooler with superior performance
Optimum Tubing Length
400 mm long tubing enables effortless mounting of the cooler in any orientation
Revamped fans
The brand-new fan blades and revamped aesthetics deliver outstanding performance and a fresh look
Longer tubes for easy placement configuration
TOP installation
Front installation
UPDATED CPU COMPATIBILITY
The Core II is compatible with all of the latest AMD and Intel CPUs
SUPPORT LGA 1851 RL-ILM SOCKET DESIGN
INCLUDED CRYOFUZE THERMAL PASTE
TUBE CLIPS INCLUDED
