Big Possibilities, Small Size
MasterBox NR200P V2
Compact yet powerful
Stay cool under pressure
Optimized GPU performance
Comprehensive GPU support
Easy, tool-free access
USB 3.2 Gen 2x2 Type C support
Refreshed NCORE style
Cooling System
240-280MM
LIQUID COOLERS
18.25L
ULTRA-SLEEK DESIGN
Extra Cool
120MM
BOTTOM FAN
COMPREHENSIVE GPU SUPPORT
Includes vertical mounting options, a custom PCle 4.0 riser cable, and a support bracket for GPUs up to 356mm in length and 160mm in height.
USB 3.2 gen 2x2 Type C support
A USB 3.2 Gen 2x2 Type C port is built into the 1/0 panel with up to 20Gbps transfer speeds.
All external panels are secured with pins for easy removal, facilitating quick access to the internals without the use of tools while a removable GPU panel simplified the installation process.
The new NCORE Style
An NCORE redesign provides a sleek take on maximizing cooling performance and style simultaneously.
Build Small. Play Big.
This case is compatible with SFF-Ready Enthusiast GeForce cards, so you can pack high performance into a smaller footprint. Look for SFF-Ready Enthusiast GeForce Cards to get a sure fit and streamline your PC build.
