Hyper 622 Halo White
ARGB Auto Detection
Broad Case Fitment
Aluminum Top Cover
Dual Redesigned Halo² Fan
Dual Tower Heat Sink with 6 Heat Pipes
ARGB AUTO DETECTION
Intuitive LED detection automatically provides default ARGB spectrum lighting or full ARGB customization via 3-pin header connection.
DUAL REDESIGNED HALO² FAN
Dual loop LED 120mm Halo² fan features stunning lighting with improved fan performance,
DUAL TOWER HEAT SINK
Dual tower heat sink and dual fans deliver twice the surface area for superior cooling.
PERFORMANCE HEAT PIPES X 6
Complete CPU coverage nickel-plated base with 6 uniform heat pipes transfers heat evenly and quickly
BROAD CASE FITMENT
Low profile heat pipes optimized at 157mm height accommodates most RAM and case requirements
