Cool Efficiency Redefined
Cooler Master’s masterclass HYPER 212 series makes a triumphant return with the HYPER 212 PRO, a new take on a classic design featuring our in-house design heat pipes.
The newly designed CPU cooler introduces an all-new heat pipe, increasing the TDP to 230W. This means it can handle the cooling of higher power CPUs effectively
A novel asymmetrical heat pipe layout and design provides more RAM clearance than ever before.
The optimized design ensures better airflow and heat dissipation, which results in improved cooling efficiency and overall system performance.
By using various evaporator and condensor wick structures, our SCHPs greaty enhance performace for improved heat dissipation
A sleek and modern top cover enhances the overall look of your build, giving it a stylish and professional appearance.
A SickleFlow Edge fan combines exceptional heat dissipation performance with a visually striking design.
Simplifies the installation process, allowing users to set up the cooler quickly and efficiently.
