Relaxation at Your Command
Say goodbye to the perils of prolonged sitting! The Hybrid M Chair is the game-changer you've been waiting for, designed to tackle the muscle pain and discomfort that plague gamers and office warriors alike.
Redefining Comfort For Gamers And Work Heroes
Imagine experiencing instant relief right in your seat! This innovative chair incorporates a massage module seamlessly into its frame, offering a soothing touch that melts away tension and discomfort as you work or game.
Built-in Massage
NO CORDS, NO LIMITS, MASSAGE ANYWHERE
Unrivaled freedom with the Hybrid M, discover the experience.
Massage Control App
CUSTOMIZE YOUR MASSAGE YOUR WAY
With the Hybrid M App, you're in control. Record and personalize your massage programs effortlessly or simply use the built-in joystick in the armrest to adjust your massage. Whether you crave a soothing, stress-relieving session or a powerful, invigorating massage, it's all at your fingertips.
*Android Playstore App in development.
Our Achievements
AWARDS
Air-Flow Comfort, All-Body Ergonomic
Experience a chair that cares for your well-being as much as you do. Embrace a new standard of relaxation, efficiency, and comfort. Revolutionize the way you work, play, and conquer - because comfort shouldn't be a luxury; it should be a standard. Our exclusive cold molded-foam technology vastly improves air ventilation and reduces heat buildup in the Hybrid M. The premium molded foam serves as an extremely comfortable base, conforming to your body and allowing you to sit on the Hybrid M for even the longest of work and play days.
Comfort
ADJUSTABLE NECK SUPPORT
Comfort
UNIBODY COLD MOLDED FOAM
75MM
SILENT CASTER
Adjustability
3D ARMREST
4CLASS
GAS LIFT
Comfort
Quick Stow Magnetic Lumbar Support
Hybrid M's Magnetic Lumbar Support provides a convenient solution for comfort and support. With fast magnetic height adjustment, users enjoy personalized comfort at their fingertips. During the massage function, the lumbar support can be swiftly stowed away under the seat, keeping it out of sight but always close by. Experience unparalleled convenience, functionality, and ergonomic support with Hybrid M's Magnetic Lumbar Support System.
Materials
Premium Steel Frame And Aluminum Base Construction
Made from a rock-steady steel frame in combination with a premium aluminum base, the Hybrid M is built with high-quality materials that is not only reliable, but will last for years on end.
Video Tutorial
EASY SETUP & CUSTOMIZATION
The official step-by-step guide to assembling your new Hybrid M Chair and customizing it to perfection using the Cooler Master app.
Chair Recommendation
TABLE OF MEASURES
