經典進化 全面之選
SickleFlow 80 8公分PWM風扇
延續SickleFlow系列,酷碼推出全新升級的的SickleFlow 80風扇系列,為玩家帶來更強的散熱效能。針對扇葉曲面有了進一步優化,大幅提升風量、風壓的效能表現。強化的風扇框架有效降低擾流以及噪音的產生,並增加整體工作效率。風扇軸承採用全包覆設計,更可以保證風扇的運作的穩定性以及使用壽命。
OPTIMIZED FLOW AND PRESSURE
Continuing the SickleFlow 120 series , Cooler Master introduces a new models with brand new upgraded design features for enhanced performance.
The new SickleFlow 80 fan blades are created with bigger blades and increased curvature to optimize the air flow and air pressure performance. Strengthen structural frame design with added rib housing for durability. Improved dustproof and oil leakage prevention for beater life expectancy,
Improved Frame Durability
Enhanced square frame structure with added rib-support for reducing turbulent flow, noise and increasing overall work efficiency.​
New Air Balance Blade
Optimized fan blade design with increased curvature that improves air flow and air pressure.​
New Bearing Sealant
Two-tier sealing mechanism designed to improve dustproof capabilities and prevent lubricant oil leakage for extended life span and performance.
