CK570 SF6 Chun-Li Gaming Keyboard
The Cooler Master CK570 Mechanical Keyboard is the ultimate customizable keyboard for gamers.
Special Edition
Cooler Master
x Capcom Street Fighter 6
The CH331 SF6 CHUN-LI headset, with its exclusive
color scheme and design, weaves together the aesthetics
of Street Fighter 6 and Cooler Master's audio expertise,
embodying the spirit of Chun-Li.
Keyswitch
CHERRY
MX SWITCHES
Gasket structure
Gasket structure and cushions work to reduce vibrations and noise for a more comfortable typing experience while retaining durability
Durable
PBT double-injection keycaps with side print
Made of a high quality PBT doubleshot construction process which prevents the fonts from fading while allowing for RGB backlighting to shine through
*PBT is only for US and TC layouts
MasterPlus+ Suite support
The CK570 is one of the first Cooler Master products to support the new MasterPlus+ software, a unified control hub where managing all of your Cooler Master gear is easier than ever. Adjust all of your settings from one dashboard, and even sync your lighting settings across multiple devices with ease.
Take control with a precision dial
Three-way precision dial enables you to adjust volume, cycle through color modes, and more — all customizable via our MasterPlus+ software.
Improved Ergonomics
TWO-STEP KICKSTAND
Adjustable feet improves the ergonomics of the CK570 by letting you control the angle of the keys to reduce wrist strain.
RGB backlightning
No-nonsense backlighting for a no-nonsense keyboard - illuminate your keys based on control schemes, or just do it because it looks cool with 16.7 million colors to mix and match.
