가이드 및 리소스
PC 빌딩 경험을 향상시키기 위한 포괄적인 가이드, 튜토리얼, 리소스를 만나보세요. 전문가 팁, 상세 매뉴얼, 문제 해결 조언을 통해 맞춤형 빌드를 최적화하세요. 초보자와 숙련된 빌더 모두에게 완벽한 자료입니다.
쿨러마스터가 인텔 Core Ultra 200S CPU를 위한 차세대 냉각 솔루션을 제공합니다.
COOLING X: 데스크에서 클라우드 서버 품질
For over 30 years, Cooler Master has led the way in industrial server cooling and pioneered PC components for gamers, creators, and PC enthusiasts. Cooler Master’s Cooling X leverages our experience and the same industrial-grade materials, design, and thermal engineering used in the world's most advanced servers and supercomputers, to deliver a prebuilt system unlike any other.
간략한 개요 : AI, ML, DL 및 AI PC의 중요성
As we venture further into the rapidly evolving world of personal AI computing, this article will explore the fundamental concepts of Artificial Intelligence (AI) and AI PCs, addressing some of the computational challenges and hardware demands they entail. Leveraging Cooler Master’s expertise in AI server cooling solutions and industry insights, we aim to shed light on the imminent shift towards AI-driven personal computing. Our goal is to use our unique knowledge and technologies to create a seamless AI PC experience.
ATX 3.1이란 무엇인가: Cooler Master가 최신 표준으로 GPU를 보호하는 방법
The main change that comes with the ATX 3.1 PSU spec is the new 12V-2x6 power connector, which fixes all the reliability issues present in the ATX 3.0 12VHPWR connector.
최고의 PC 팬 설치 방법: 케이스 냉각 개선하기
How to optimize your PC cooling performance with the best fan configuration.
ATX 3.0이란 무엇인가요?
ATX 3.0 is a PSU specification standard released by Intel. ATX 3.0 is optimal for high-power gaming and streaming, and essential for Nvidia 40 series GPUs.
MOBIUS 모비우스 시리즈의 기술 발전
Cooler Master’s in-house designed Mobius series case fans feature several technological evolutions, making them the star of the next generation of cooling technology.
CYBENETICS 소음 수준이란 무엇인가?
Cybenetics calculates a PSU’s overall noise output by averaging testing noise measurements, and then certifying the PSU with a noise level rank.
ATX 또는 SFX: 어떤 PSU가 당신에게 적합할까요?
Generally, SFX PSUs are best for small form factor cases or otherwise compact machines that don’t have much space for other components like cooling systems, while ATX PSUs are for larger, regular cases.
PC에 수냉 쿨러를 설치하는 방법
Installing an AIO CPU liquid cooler in your PC is pretty easy if you follow these steps.
RGB 또는 ARGB? 차이점은 무엇인가요?
RGB lighting is LED-based lighting that allows for more than 16 million color variations. ARGB lighting allows for more complex lighting displays via control of each individual LED.
PC 케이스는 어떻게 선택하나요?
When choosing a PC case, it is important to consider the form factor, features, and aesthetics. Ensure that all components will work and fit together properly, and that the case you have selected can support the kind of tasks you want your PC to perform.
AIO 리퀴드 쿨링 vs 에어 쿨링, 어떤 것을 선택해야 할까요?
Air coolers and AIO liquid cooling are both effective methods for cooling your CPU. Which you choose is largely a matter of personal preference.
PSU를 안전하게 설치하는 방법은 무엇인가요?
Safely installing a PSU while building your PC is not too complex. If you follow the steps of this guide and your product’s instructions slowly and carefully, everything should go smoothly.
PSU란 무엇인가요?
A PSU plugs into a wall outlet and converts the AC power supplied to your home into low-voltage regulated DC power to be used by your PC. As the heart that powers the entire machine, the PSU is among the most important components in your PC.
SFX PSU란 무엇인가?
SFX is a small form factor PSU design specification. Small form factor refers to a smaller-than-usual computer component. SFX power supplies are significantly smaller than ATX PSUs.
ATX PSU란 무엇인가요?
ATX (Advanced Technology eXtended) is a specification for motherboards, PSUs, and cases. The specification defines sizing, I/O panel location, mounting points, and other factors that ensure each PC component fits together in a standardized way.
소비 후 재활용 재료란 무엇인가?
Post-consumer recycled (PCR) materials are made from consumer recycled materials and are used to make new products. PCR materials can be used in the composition of materials such as aluminum and plastic, and in the manufacturing of packaging, consumer electronic goods, and more.
80 플러스 효율성이란 무엇인가요?
80 Plus efficiency is a certification program that proves the efficiency of PC power supply units. An 80 Plus certified unit is guaranteed to be at least 80% efficient at loads of 20%, 50%, and 100%.
PSU를 선택하는 방법은?
When building a PC, you need to know the 3 most important factors for choosing a PSU: wattage, form factor, and efficiency. We have compiled a list of the 3 most important factors to consider when choosing a PSU for your build.
초전도 복합 히트 파이프의 힘
CPU coolers are one of the most important components that ensure a powerful PC can run smoothly. The CPU is the brain of every PC and if it overheats it will cease to work properly, effectively shutting down the entire machine.
