• Shop Now
    Shop Now
    • Prebuilt Gaming PCs
    • Online Store
    • Special Deals
    Shop Now
    Online Store
  • Products
    ProductsProducts
    • Cooling
      CoolingCooling
      • Air Cooling
      • Liquid Cooling
      • Case Fans
      • Thermal Paste
      • Laptop Cooling
      • Standard Cooler
      • Phone Cooler
      • Accessories
    • PC Cases
      PC CasesPC Cases
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • PC Case Accessories
    • Power Supplies
      Power SuppliesPower Supplies
      • X Series
      • V Series
      • V SFX Series
      • GX Series
      • MWE Series
      • Elite Series
    • Accessories
      AccessoriesAccessories
      • Monitors
      • Keyboard
      • Mice
      • Audio
      • Mouse pads
      • Controllers
    • Furniture
      FurnitureFurniture
      • Chairs
      • Desk
      • Accessories
    • Systems
      SystemsSystems
    • MasterHub
      MasterHubMasterHub
      • MAX
        MAXMAX
        • ATX
        • Mini ITX
      • Immersive Experience
        Cooling
        360 DEGREES OF COOL
        PC Cases
        CREATED ONLY FOR THE BEST
        Power Supplies
        PRECISE SILENT POWER
        Furniture
        RELAXATION AT YOUR COMMAND
        Systems
        COOL. COMPACT. QUIET.
        MasterHub
        MAX
      • Builder's Zone
        Builder's Zone
        • PSU Calculator
        • CPU Compatibility
        • Guide & Resources
        Builder's Zone
      • Software
        Software
        • MasterHUB
        • Masterplus+
        • Masterctrl
        Software
      • Support
        Support
        • Product registration
        • Tech support
        • Warranty
        • Warranty check
        • Faq
        • Contact us
        • Return Policy
        • Shipping Policy
        Support
        Special Announcement
      MasterAir MA824 Stealth
      Overview
      €69.00
      1. Home/
      2. Cooling/
      3. CPU Air Cooling/
      4. MasterAir MA824 Stealth CPU Air Cooler
      Eight Recreated
      Cooler Master is unveiling its flagship air cooler and newest addition to the Stealth Series – the MA824 Stealth.
      €69.00
      8 In-house Designed Superconductive Composite Heat Pipes
      8 Superconductive composite heat pipes utilize groove and powder wick structure with dual variable heat pipe thickness for maximum efficiency of heat transfer.
      Performance Dual Tower
      Redesigned dual tower maximizes performance and surface area with optimized fin density and thickness.
      8 Heat Pipe Array
      Optimized lay out consisting of 8 heat pipes to ensure the heat is transferred to all fin area for efficient dissipation.
      Expanded Copper Base
      Expanded surface area of nickel plated copper base provides seamless contact and complete coverage to target all heat zones. Base layer thickness minimized for faster heat conductivity as well as lower cooler height for improved case compatibility.
      Dual Mobius Fans
      Equipped with dual variable Mobius fans for exceptional silence without compromising performance.
      Dual Staggered Fan Setup
      Staggered 120mm and 135mm Mobius fans create ultimate Push-Pull setup for perfect airflow and air pressure to maximize heat dissipation.
      All Black Stealth Design
      Stealth Series aluminum top cover and all black hardware provides a premium and clean design.
      Pre-applied High Performance Thermal Paste
      Key Features
      Dimensions
      Trending
      HAF 700
      The Berserker
      • About
        Corporate
        Social Media
        News
        Events
      • Support
        Product Registration
        Spare Parts Store
        Tech Spec
        Warranty
        Warranty check
        Faq
        Contact us
      CAREER
      RESOURCE CENTER
      • Privacy policy
      • Terms of use
      • Cookie policy
      • Conformity of products
      Confirm your Country
      The page you're looking shows Cooler Master contents for European Union.
