Focusing on the Essentials
GM238-FFS
The GM238-FFS is a 23.8" FHD monitor equipped with an UltraSpeed IPS 144Hz panel, featuring Dynamic Overdrive, Adaptive Sync, and 90% DCI-P3 coverage. This no-nonsense monitor focuses on the essential features needed for gaming, productivity, and content creation, making it the perfect addition to your work and play setup.
€169.00
Ready For Any Situation
The 23.8” Full HD 144Hz display combined with 90% DCI-P3 wide color gamut makes the GM238-FFS an incredibly versatile monitor. With features essential for both gaming and productivity, you can have the freedom to play your games without a hitch or focus on your work.
Ultraspeed IPS with Dynamic Overdrive
Equipped with the latest Ultra-Speed IPS panel, GM238-FFS is up to 4x faster than traditional IPS panels. The pixels transition faster to other colors and scenes, leading to an exceptionally smooth picture with significantly less motion blur or smearing.
Dynamic Overdrive is also specifically tuned for the GM238-FFS, automatically selecting the most optimal overdrive settings based on the refresh rate for an even smoother experience.
Smooth Operator
Adaptive Sync delivers smoother gameplay that accurately reproduces a level of realism to everything you play. By synchronizing the output frames from your GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is more fluid than ever.
Incredible Color Detail
Covering 90% of the DCI-P3 color spectrum and 120% sRGB, the GM238-FFS is able to accurately reproduce the colors the way the creators intended for you to see it in your games and entertainment.
Details Plenty
Offering 92.6 pixels-per-inch (PPI) for a 23.8 inch monitor, the GM238-FFS with its Full HD resolution offers a great balance of visual fidelity and performance.
Make It Your Game
Easy On The Eyes
Protect your eyes from potentially harmful blue light with our Low Blue Light Mode. Our monitors are also Flicker Free, further reducing any eye strain and allowing you to get more work or gaming done.
Get Connected
Connect a multitude of devices to your monitor with 2 x DisplayPort 1.4 ports as well as 2 x HDMI 2.0 ports.
